ConBee III
The deCONZ application is a tool to configure, control and monitor Zigbee networks with the ConBee III.
ConBee III / deCONZ / Phoscon App
Supported platforms
Connection
To ensure a strong radio signal, the ConBee III should preferably be connected to a USB 2.0 socket with an USB extension cable.
ConBee III USB cable
  • Prevents interference with housing and peripherals
  • Provides maximum signal range and reliability
Note
Connection problems may occur if the ConBee III is attached directly to the USB port or is located near USB 3.0 devices such as external hard drives or memory sticks.
Supported Raspberry Pi models and distributions
Note
Installing the Operating System
  1. Download and launch Raspberry Pi Imager from the website www.raspberrypi.com/software
Raspberry Pi Imager Start Screenshot
  1. Insert the SD card into your PC or an SD card reader.
  2. Raspberry Pi Device: Select your Raspberry Pi model.
  3. Operating System: Select a current operating system.
  4. Storage: Select the SD card drive.
  5. Use OS Customisation: Click No if the default settings are acceptable, for example, if you are using an Ethernet cable and have direct access via a connected mouse, keyboard, and monitor. Otherwise, click Yes to adjust the settings: hostname, username, password, Wi-Fi, time zone, and keyboard layout, and save them with save.
Raspberry Pi Imager Edit Screenshot
  1. To access the Raspberry Pi remotely, i.e., without a connected mouse, keyboard, and monitor, it is important to enable the SSH interface under the Services menu. Furthermore, you should assign your own login credentials under Set username and password.
  2. Write: Start the copying process
  3. Remove the SD card from the card slot (eject it in Windows Explorer → right-click on the drive letter and select Eject)
  4. Insert the microSD card into the Raspberry Pi’s SD card slot
  5. Connect the USB cable to the Raspberry Pi. The operating system will start automatically after approximately three seconds and will be ready for use after approximately one minute.
Remote Access
Remote access to the Raspbian OS desktop is via the VNC interface. This must first be enabled after successful operating system installation.
  1. To do this, log in to the Raspberry Pi using a suitable SSH console program via its IP address, with the previously assigned Username and Password, and enter the following command:
     sudo raspi-config
  2. In the menu item 3. Interface Options, set the I3 VNC option to Enable.
  3. Restart the Raspberry Pi
You can now access the Raspbian OS desktop using a suitable VNC program.
deCONZ Installation
  1. Set user USB access rights
     sudo gpasswd -a $USER dialout
    Note: Changes to access rights only become active after logging out and in or after a restart.
  2. Import Phoscon public key
  3. Configure the APT repository for deCONZ
                generic main' > \
    Beta (alternative)
                generic-beta main' > \
  4. Update APT package list
  5. Install deCONZ
    When using an older distribution (before Debian Bookworm)
    When using a current distribution with Qt6 (from Debian Bookworm onwards)
  6. Create UDEV rule
     echo ACTION=='"add"', SUBSYSTEMS=='"usb"', \
          ATTRS{product}=='"ConBee III"', \
          RUN+='"/bin/stty -F /dev/%k 115200"' | \
          sudo tee /etc/udev/rules.d/99-conbee3.rules
    Note: The ConBee III gets activated after a restart or unplug / reattach.
Auto start of the deCONZ GUI (optional)
Start the GUI service every time the system starts.
Troubleshooting
If problems occur during the installation, the Support section answers frequently asked questions (FAQ) and provides further assistance.
Supported Ubuntu versions
                generic main' > \
    Beta (alternative)
  5. Install deCONZ
    When using an older distribution (before Ubuntu 24.04)
    When using a current distribution with Qt6 (from Ubuntu 24.04 onwards)
  6. Create UDEV rule
deCONZ Ubuntu
  1. Open the Startup Application Preferences via the application menu
     gnome-session-properties
  2. Add a new entry with the following commandline:
    deCONZ Ubuntu
Troubleshooting
The SD card images as well as the standard installation method start automatically with graphical user interface.
Switch off graphical user interface (headless)
To switch off the graphical user interface (GUI), the following commands must be entered in the console:
  1. Stop the GUI service immediately.
  2. Start the headless service now and every time the system starts.
Switch on graphical user interface (GUI)
To switch on the graphical user interface (GUI), the following commands must be entered in the console:
  1. Stop the headless service immediately.
  2. Start the GUI service now and every time the system starts.
Home Assistant ZHA
Supported versions
Minimum requirements:
Update ConBee III
The ConBee III firmware must be updated manually via the command line as described in the wiki article Update ConBee III firmware manually and Youtube-clip, to ensure a proper function with the ZHA integration. The updae proces behaves exactly like the ConBee II update. The necessary update tool GCFFlasher is available as stand-alone version for download.
  1. Login into Home Assistant web interface and open the Settings section.
    HA settings
  2. Open the settings of the System and switch to the Updates section.
    HA settings system
  3. Update the Home Assistant core at least to 2023.12.0.
    HA core version
  4. Open Devices & Services in the settings section.
    HA devices and services
  5. Search and add the ZHA service.
    HA ZHA
  6. Configure the ZHA integration to set up the ConBee III.
    HA ConBee III integration
  7. Define the network formation: keep network settings, upload a backup or create a new network.
    HA network formation
Supported host systems
macOS installation
  1. Download deCONZ.
  2. Unzip and start deCONZ.
    Unzip the file deCONZ_macOS.zip in Downloads and start the application deCONZ.app.
Windows 11 installation
  1. Install USB driver.
    The drivers are installed automatically after connecting the ConBee III. If necessary, the drivers are downloaded from the Internet. Alternatively, the necessary drivers can be downloaded from the official manufacturer website https://ftdichip.com.
  2. Download deCONZ software.
  3. Start deCONZ installation.
    Select and execute deCONZ Setup .exe-file in Downloads.
  4. Confirm installation of unknown app.
    1. Select More information.
    2. Start deCONZ installation with Run anyway.
  5. Follow the instructions in deCONZ setup.
  6. Start deCONZ in Search input.
Windows 10 installation
Update directly in the web browser
The ConBee III firmware can be updated in the web browser. Currently, only Chrome and Edge are supported.
  1. Open the Online Firmware Updater
    ConBee 3 Webupdater
  2. Connect the ConBee III to your PC/laptop
  3. Perform the update
Done!
Update manually
The firmware of the ConBee III can be updated manually. An tutorial video for the update under Windows is available on Youtube:
Furthermore, the individual steps, also for other operating systems, are described in the FAQ.
Factory reset
The ConBee III could be reset to factory new settings by using the integrated service button.
Reset to factory new
The following parameters are reset to factory new settings:
